Ok, im building an iron 408 for a buddy of mine that im also swaping into a 96 S10 with a T56 trans. Were are using all LS2 top end stuff on top if the block, and wanted to see if a GEN 4 valley cover for and engine without DOD will work. Were using the stock 6.0 cam and crank sensors, and not the LS2 front cam sensor, and will also be using LS2 knock sensors. and LS2 oilpan and Truck accessory drive.
Thanks for the help.
