Results 1 to 8 of 8
Thread: Custom front mount single turbo setup for sale
Threaded View
    May 2007
    Las Vegas, NV
    I’m seriously debating changing my turbo setup to twins so my front mount single setup is up for sale. I built the setup myself; all piping is .065” thick 304 stainless from Stainlessworks. The manifold flanges are from them as well and are 3/8” thick.
    Asking $2499 obo Shipped in the Continental US
    Open to reasonable offers :cheers:
    Garrett GT4294 turbo
    TurboByGarrett.com - Catalog
    1.15 A/R turbine housing, probably less than 20 street miles and 8 ¼ mile track passes at 5.5 psi (new to tuning, the Chevelle ran a 14.05 @ 105 mph leaving off idle with a dismal 2.488s 60’, internally stock LQ4, stock 4L80E, 1600rpm converter, 3.73 rear gear, 26” street tires)
    T4 flange turbine housing 4” V band turbine outlet
    5” compressor inlet and 3” V band compressor outlet
    Tial 44mm v-band flange waste gate 11 psi spring
    Manifold to turbo piping is 2.5”
    Manifold flanges are 3/8” thick stainless steel
    Downpipe is 3.5” and has two O2 sensor bungs
    K&N air filter
    Stainless 48” flex radiator hose
    Oil supply and drain lines stainless steel braided hose, aluminum AN fittings
    Support bracket for mounting turbo to alternator/power steering bracket
    ***Does not come with cold side piping, intercooler or bov***
    ***If I didn't list it above, it does not come with the package***
    I’m not sure how I would ship the downpipe as it is; I would probably have to cut it into two pieces, but should be easy to reassemble.
    I’m fairly certain that this will fit on a fullsize truck and took a couple of pics with a measuring tape for reference. If you need any additional measurements or pictures, just let me know.
    If you want to see what this size turbo is really capable of, do a search for CurtD on performancetrucks.net…he has one on his truck with a built 5.3L running 12.0 @ 120 mph, making 619 rwhp and 657 ftlb PerformanceTrucks.net Forums - Dynoed today
    More pics can be seen here:
    Picture548.jpg - Image - Photobucket - Video and Image Hosting
    Picture551.jpg - Image - Photobucket - Video and Image Hosting
    Picture555.jpg - Image - Photobucket - Video and Image Hosting
    Picture553.jpg - Image - Photobucket - Video and Image Hosting
    Picture556.jpg - Image - Photobucket - Video and Image Hosting
    Picture554.jpg - Image - Photobucket - Video and Image Hosting
    Picture545.jpg - Image - Photobucket - Video and Image Hosting
