im having serious lean problem according too my a/f gauge .digging all over for answers.just checked plugs too see what there telling me .like it says is yellow rich or lean? thanks.
Are Ya Kidding Me ,no Quick Answers?
Spark Plug Analysis
See if this helps
Thanks But I Guess Im Running Good From What I Can Tell Plugs Are Very Clean And No Deposits Only Beeni N 200 Mls.my Others Before L/ts Were Nice Light Brown .iwas Ruunning Alittle Rich .this Problem Never Happened Before The L/t Install.
The tip of the insulator's color indicates only if you are using the correct heat range. You need to look way down inside the plug at the junction between the insulator and the body of the plug. How far up the insulator the carbon ring extends indicates how rich it is. And if you are checking full throttle mixture, the only accurate way is to put in new plugs, do a WOT pull, and before you let off the gas, kill the ignition. Then pull off the road and pull your plugs and look at them. Otherwise, if you do a pull, then cruise, then idle, then shut it off, what you will be looking at is the idle mixture.
foggy's "spark plug analysis" even states right at the top that it is a heat range analysis.
I'm not sure that going purely by color for heat range analysis is accurate with today's fuel.
But as far as mixture goes, what I described still holds true. Haven't you ever wondered what those mechanics at the track were looking at with their lighted magnifying glasses in the spark plugs?
2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
From your scans today it's running ok, I think the wb is band.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
