Thread: lowering compression ratio
    Mar 2007
    can you lower the compression ratio by installing thicker head gaskets? I'm wondering if i can install thicker head gaskets and run about 15psi instead of the 10psi i'm running now. thanks for any info.
    Apr 2005
    Quote Originally Posted by hotcornernoprob View Post
    I thought the factory gaskets were the thickest (.05x)?
    Cometic makes stock, .040 & .045 that I know of. Other guys are more versed in this stuff than I am though.
    Gone, but not forgotten!
    Jan 2006
    I think you would need a 6.0L head that is 71 cc or something close. Your heads I think have smaller chambers.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jan 2006
    I think you would need a 6.0L head that is 71 cc or something close. Your heads I think have smaller chambers. But then I do not think they would fit a 5.3L i am not sure.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
