Thread: Tranny cooler fittings
    Apr 2004
    I'm putting a 5.3l in an '85 4x4 frame and I've got a radiator out of a 2000 Silverado. The fittings in the radiator for the tranny cooler lines are a push in style and I'd like to adapt them to use flare fittings. Does anyone know if there are adapters to do this that are readily available?
    Thanks,
    Gus
    Aug 2006
    Willis, TX
    Quote Originally Posted by Speedo View Post
    Thanks,
    Gus
    Gus I looked around on the internet and didn't find anything..you may want to cal hayden @ 800-433-7508
    couldn't you get two short pieces of line from a junk yard that fits into the 2000 radiator and flare the other end ...then you could use an adapter between the old and new. or maybe they make a slip on compression style coupler that would slide over both lines... but that would probably only work if the OD is the same between the two line
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    Jan 2005
    Humble/Houston TX
    there is a part readily available but im not sure what size.
    old mod list: H/C/I/N/E/G 408
    Aug 2006
    Willis, TX
    scroll to the bottom of this link see if this is what your looking for..kind of hard to tell in the picture...i tried calling them but their sales rep was on another line
    ph#800-303-5874
    Flo-Dynamics - ATF2000+ Hoses
    Edit: they called me back and said you need these two parts: P/N 942163 (GM 3/8 adapter) and P/N 942169 (quick disconnect adapter)
    Facebook
    Apr 2004
    Quote Originally Posted by Gator View Post
    ph#800-303-5874
    Thanks, I'll give them a call tomorrow.
    Gus
    Apr 2004
    I was out in the shop this morning and took the push in fittings out of the radiator and low and behold they are just an adapter screwed into the cooler, and I just need to screw a common 3/8" flare fitting into the radiator in place of the adapter that GM uses.
    Gus
