my pulley on my s/c is a 3.33 what should ibe getting for boost from this ,my brand new gauge is messed up it goes anywhere from 5lb of boost cruising at 60 to 14 lbs getting into it and is this determined lb of boost supposed to be consistant hot or cold out
