Results 1 to 10 of 42
Thread: mass air sensors
    Jun 2003
    well i was on my way to nelsons when i discovered a problem. no top end. got to checking and found my mass air sensor only going to 14.4. it should go to at least 28 to 42. well we put in a granatelli. it does affect timing and fuel. and i believe it is himndering me greatly.going to put on another Z06 mass air and retune. just thought oi would share that with everyone
    formerly 02denali 12.79@107
    Jasper, Ga.
    So you like the Z06 mas over granatelli? How much did it affect your truck?
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    Jun 2003
    i acn tell you that the Z06 i had went to 36 to 34 max. the granatelli goes to 29 max.so i am experienceing good things with it
    San Marcos Texas
    So which one do you prefer? How did your stock one compare?
    Florida
    is it worth the $$ also?
    485rwhp/440rwtq SAE
    i had that one sitting in storage for a while and still hadn't used it, does that tell you anything, hahah,
    i'm still running the stock one. i think it's like a 50% chance that is will work out for you.
    allen
    Jun 2003
    well the granatelli flowed at 29.98.
    the factory went to 28.9 to 29.89.
    my Z06 goes to 33.7 to 34.8.
    now that is what i am talking about. ltrims -3.47 to -5.47 cruising and 0.00 at wot.
    timing is at 30.4 when at wot and shifting. now she is up and running good.
    May 2003
    Sunny San Diego,Ca.
    what part# is that ZO6 sensor? Thanks!!!!
    00'ECSB 4.8L, Auto 4L60E with Fully adjustable TRANSGO shift kit with Superior billet servos, B&M tranny cooler, 4:10's,eaton posi, K&N Gen. 2,Thorley Headers, ASP Crank pulley, LT1 Fans, 3" catback single flowmaster 40 series exhaust, NELSON PERFORMANCE PCM BADASS TUNING, egr trim. Jantzer performance Ported TB, 20x9 MKW's, 2/4 drop.sold
    2006 GTO A4,HPE S+ cam,Volant, Kooks LT's, Magnaflow 3in.Catless cat back,3200 Fuddle converter,UDP. 7.49@93.57
    Coming up= Fast intake and heads.
    Jun 2003
    25341604 from gm parts direct.
    Dec 2003
    I put a granatelli on my old camaro-the car never ran good after that. I won't ever buy an aftermarket maf. I think they are a waste of money. All I've ever heard about with them is that they cause problems.
    2003 Silverado Z71,5.3, 3.73's, Taylor 10.4 mm wires, K&N FIPK, Borla Cat-Back Exhaust, Stock G80 Locking Differential
    Next Mod:
    Nelson Tuning.
    2004 Supercharged Impala SS, K&N air filter, TB screen removed
