Thread: New Brakes NEED HELP!!!
    Miami
    Last week I changed all 4 rotor, pads and brake lines(stainless steel). Rotors and pads are from SSBC and lines from Russell. Ok I did the go and stop to seat the pads in and blead the brakes . After I blead the brakes I cleaned the rubber covers to the bleed valves and clean the valves also. I made sure their was no brake fluid in any of the rubber covers or the valves. After the go and stop procedure again I removed the right rear rubber off the valve and theirs brake fuild in it. It had the most then the left rear then pass. front and bearlly nothing on driver front. I have never had this happen to me before. I acually did my wifes car about 4 month ago and no problems. So what going on. Are the bleed valves or brake calipers defective and they are the original ones(110,00 miles). Can this happen to all the brakes at once like this.Has this happened to anyone. What should I do next buy a valve or a caliper. Also do I go with a dealer caliper or auto store one. Thanks
    06 Silverado SS- Magna Charger Radix 3in pulley, LT's, C.A.I, Cat-Back exhaust, Shift kit with 2 and 4 servos, 160 t-stat. Taylor 10.4 wires
    Miami
    Well I found my problem and its the bleeder screws. I tried a couple of things to fix them but no luck. Im going to need new calipers. What brand you guys recommend. The dealers are pretty expensive any other good alternatives. THANKS
    Jul 2006
    College Station, TX
    Well what size rims do you have?
    2004 EXC Silverado 6.2L
    Mods:
    can't get new bleeder screws?
