Im getting ready to drop in the engine, what fuel pump do i use what mods will i have to do to make it work? and also i have an ls1 intake with fuel rails, wondering what do i need to make fit with same fuel lines...thanks!
96-98 pump will work. since the tanks are the same as the 91 it should be a fairly easy swap. or go to a pull a part & grab a whole tank & everything from a 96-98.
you going to have to make or have some lines made. i had to make 2 short lines to go from my factory truck lines to the vette filter, then a new line from the filter to the rail.
http://i22.photobucket.com/albums/b3...s/DSCN1685.jpg
http://i22.photobucket.com/albums/b3...1/DSCN1663.jpg
I recommend an aeromotive 340 stealth. But it will have to be "retro" fitted. I figure if you every want to do upgrades, this fuel pump will be able to supply.
I believe the stock fittings are M14(return) and an M16(feed) on the lines shown above.
Here is the pump i used http://www.highflowfuel.com/i-478352...1988-1995.html
Fuel pump is same as Grand National pump. Search for Walbro F20000169. Very cost effective, get the kit that includes sock and wiring and you're done.
Diggin that 1/2" rebar re-enforcing the framerail!!
think i used -6 on mine.
[QUOTE=RPM Graphics;519045]96-98 pump will work. since the tanks are the same as the 91 it should be a fairly easy swap. or go to a pull a part & grab a whole tank & everything from a 96-98.
Do you by chance remember the part # for that braided/flex line and the connector to the fuel rail?
i got the braided line from a friend. i bought my vette filter kit from speed way & it came with the push-lock fitting for the rail. i just had to buy some an-6 fittings for the lines, i'll see if i can find the part numbers to the fittings.
