What has everyone done as far as cooler lines? I think I'm going the AN fitting route and bypass the radiator cooler.
I just use to rubber hose that comes with them.
Why bypass the radiator?
mine comes from the transmission, into a rubber hose going into my tru cool, then out of my cooler thru a rubber house into my radiator, then back to the transmission.
Why would you cool it down, then heat it back up before entering the transmission?!
jake, you need to find a new installer hahaha
Are you sure its not going into the radiator then to the tru cool and back to the trans?! That i can understand...
Good deal!
Does it actually get cold enough up there to run it through the trans?! Why not just bypass it all together?
True cool has a temp bypass built in. My front pump fried and don't want to chance not getting all the metal flushed out of the radiator cooler.
i need to invest in a tru cool very soon...my 6spd hits 220 hot lapping at sar last year and that was without a stall....now i have one
What he said ^^^
I finally bought one last week and it didn't come with the thermal bypass.
To my knowledge all of them have it. It goes through the top two tubes and back to the trans.
Oh ok. Do you know if it is internal if it has that. Option or is it external? Where did you order yours.
Its external I believe. You can order that part separate.
Ill just cover it up partially when it gets cold. Should be fine.
it can get 35 below here lol and im bypassing the radiator
The trucool has a temperature bypass design built into the cooler itself. There is a video somewhere that shows fluid flow through the cooler and how it changes with the fluid temp cold vs hot.
Only some have the bypass, it depends what you order.
And again, why bypass the radiator?
No bypass
http://www.transmissioncoolers.us/Me...ool-MAX-cooler
With bypass
I was thinking about the low pressure drop trucool setup. Sorry
No problem.
