Has anyone turbo'd a ls motor s-series?
I am wanting to turbo the 01 blazer. Currently I have the following mods
2006 6.0 lq4
227/227 .614 115lsa lsl cam
"cold air intake"
2 lt1 electric fans
Sanderson shorty swap headers
x pipe and Magnaflow y muffler
Stock intake
stock 317 heads with spring and trunion upgrade
built 4l60e with Vigilante 3200 multidisc converter
8.8 with 4.10 gear 31 spline axles
275/50/15 drag radials.
Rancho 9000 adjustable shocks in rear
78mm dual stage NITROUS OUTLET plate
36lb injectors
walbro 255 intank pump
I thought about getting a kbracing or tick performance turbo kit but just now saw the deadline on the "special pricing" :(
I am sure someone has done it or knows someone who has done it. I understand that I will need to upgrade my fuel system of course. But as far as the turbo setup that is where I kick my self in the nuts. This will be my first time with a turbo setup and I do not feel comfortable fabrication everything myself. I feel that I may do something that will make it not work effectively.
I want to turbo the vehicle. But I do feel discouraged and might just swap the cam out and put a more nitrous friendly cam in it, change the intake manifold out and maybe some other things and just spray the guys out of it. I am wanting to try and go some 6.30's in the 1/8. I have gone 7.30's right now on S/s with no traction bars or anything and not shooting until after the 60ft mark.
I am going to change out front suspension because I am unloading the rear with current stock shocks.
Sorry for the babble. But I would like someone to steer me away from nitrous and go the goal of constant 600rwhp with current setup until internals are changed.
