Currently with the rear mount, my IAT's only get up to about 15* over ambient. What kind of IAT's are you guys seeing with front mount turbos?
my last setup usually seen on average 15* above ambiet when under boost for a full pull. the times when i ran e85 mix i seen the IATs drop below ambiet on a full pull.
IAT can be effected by how effecient the setup is
Quik,
I am new to the site and I have read alot of threads where you know your sh*t. With that being said it is only my question. If the fuel is not going through the intake track how does it cool the charge? The cooling effect that alcohol based fuels provide are usually pre intake injected or carbed.
Trust me I am not arguing, I can see cyl head temps or EGTs lower, But IAT's?
If you tell me that you have datalogged the fuels back to back, I will take your word for it. I am just struggling to comprehend how.
Depends where the iat sensor is located as well
Might consider water to air with a front mount. Much shorter pipe routing. Less pressure drop. More consistent temps = Less tuning issues on multiple passes or possible heatsoak
The plan is to keep the intercooler setup like this
Attachment 3718
I'd like to run an A/W intercooler but the cost is the only thing stopping me. Keeping this intercooler is free. I also plan on relocating the IAT sensor to directly in front of the throttle body, mainly so the ECM will recognize the temp drop when the meth sprays.
who cares !... Go front mount and sell me your Old spare oil pump !.. If all u change are hot pipes it will not be much of 10 up or down of where u are now........ and like Allen said.. depends on your IAT sensor location and you have Meth kit anyway so WHO CARES ! Hurry and go front mount !... Allen Claims 100hp Gains over the Trick/KBracing stuff........ Put him to the test....
I have my IAT sensor at the front of the TB and a Trick FMI a/a. W/O meth kit I ussually saw 115F tops with a 95F ambient temp at 9psi Street Driving. Now with the meth (u help me a lot with this kit installation) (35% meth) with same ambient temp and same boost on the street I see a drop to 86-82F most of the time under boost.
Since Meth comes at 5psi, It first up some degrees and then drops.
Not backing up Quik, but comes to my attention, then when I use pure Avgas 130 I see a 2 degrees drop over normal Pump gas (92 oct). Weird, but is on the logs !!!!!!
I hear you man.
Could be bcause other variables like more timming, a little richer, more boost, and I only use avgas for racing on 11-12 psi.....don't know the answer for that one, but iat sense that !!!!
EGT temperature changes may have an effect on IAT's. Not sure which grade of avgas fuel you use but it may burn cooler. Alcohol burns a lot cooler. Keeps the turbo cooler so naturally IAT will come down.
I have a little hangar with 2 flying things in it, in the Intl Airport from the city I live, so from time to time I get some fuel for the truck. I purchase it like if it will go to the crafts, but instead I use it in the truck and the Camaro from time to time.
I buy the one in green, that is suppost to be for the turbo charge and SC planes that the AirForce here have for training (old rigs). They also sale the blue one avgas 100LL but I prefer some lead in my diet.
When I first recive my 408 form Nelson, I had no good tune to part with, so I choose to drive with avgas all the time till the tune got safer. So in that time (a 2 month), and prob a 2000 miles at most, The fuel ate 3 WB O2 sensors. The OEM O2 are long gonne, I have a SD tune.
SO I can tell you that if I daily drive it with AVgas, prob 2 weeks tops will chew a brand new O2 WB.
I got my self like 12 I bougth as spares in my garage.
Now with a safe tune on 9psi on pump gas and meth kit, the O2 WB has last 3 month till now, and still working. Had load the truck with the leaded fuel like 4 times most.
