Originally Posted by
CaMmEdHoE
Ok now go through there and read the sig's. They all have efi live which is like stacking chips on a cummins because no one makes a chip that fuels as hard or does anything to the computer like efi live can. Then also read that ALL of the trannis are upgraded, do the same upgrade to the dodge and it last the same. An also look at the hp they are putting down. A cummins with stacked chips and lift pump will do the same. An as for the fuel system they are still upgradeing there lift pumps like you have to do for a cummins, the injection pump is the same exact one the cummins has (CP3) and the cummins injection system is the strongest in the common rail 04.5 up they have three injection cycles. An you show me a page of 12 sec time slips, go to you tube and type in fastest dmax its like 11's or high 10's and then type in fastest cummins should show a pewter dodge with orange stuff on the side, he broke 9's
