Originally Posted by
NITROUS
The small cover on the right houses both LS1 fan relays and the cover on the right houses an extra fuel pump relay, extra A/C relay, fan 1 and fan 2 30 amp fuses, an extra 10 amp fan fuse, an extra 20 amp fuel pump fuse, a 10 amp PCM battery fuse, a 15 amp A/C fuse, an extra 15 amp pcm ignition fuse, and 3 extra fuses for fuel injection if needed. I made the small plug and play harness with exra features to use in other vehicles.
The gas gauge is standalone from the PCM so the sender is hooked up just like factory.
