Lowering with shorter u-bolts
Here's one that I typed up on lowering a 4WD w/ 2WD u-bolts.
http://www.ls1truck.com/forums/mecha...tml#post282636
4L60-E "Corvette" 2nd servo
http://www.sonnax.com/articles/132-A...for-the-4L60-E
According to ATSG service manual, the following 4L60-E transmissions have the “Corvette” servo installed from the factory, based on the center hole dimension on the divider ring.
The trans codes stamped on the passenger side pan rail on the trans are:
CHD CJD CKD CLD
KCD KDD
If in doubt, check the casting number on the divider ring or measure the hole.
Cheers
private discount. write my essay
Hello everyone!
Last year I got a job so I had to use paper help service cause you know how hard it can be if you dont have much time to do everything :)
Well, I spent a lot of days looking for a safe and inexpensive service with high-quality writers. And finally I found it!
One of the best essay writing service
It was so easy! I paid and received my paper on time.
And my teacher liked it :)
So am I! And for now they offered me some private 10% discount!
I gave it to my friends on campus and want to share it with you. :)
Catch https://essayerudite.com/order-form/...HELP10&aid=436 and feel free to use the service.
Good luck!
