Originally Posted by
zeake
Well Richard and Proheads.com gave a a cam recommendation after checking out the thread it is 208º/214º .554"/.559" with a 114º lobe center.
I asked him if he has a kit with all acc needed to install pushrods springs etc etc etc. I want to be sure to use good springs.
Should I replace the rocker arms during the cam swap. I want to be sure I do not have a broken rocker down the road.
Also can you prime the oil pump on an lq9 if so how? I want there to be plenty of oil where it needs to be before firing it up. I have no idea how long this motor has been sitting. The water pump is going to be replaced also.
Anyone know if the water pump is any different between the 99 5.3 and the 2002 LQ9?
Also thanks to everyone that gave there thoughts recommendations and opinions. I greatly appreciate it.
