Looks like those tires are a little skinny for the wheels or is it just me?
they are stretched, but im running a 275 on an 11 which is within the factory specs on the tire, not super stretched like a 205 on a 10.5 or anything like some people do. Cant really run any larger on a gto without modding the suspension/fender tubs anyhow, so im not really sacrificing a lot of width with a 11.2 inch tread width. I wanted larger lips so i had to stretch the tire on there. Since the falken i have on here now comes with a "rim protector" feature in the sidewall, it causes it to poke a little, which im not really into, and some other tires dont really do..but im willing to deal with it and have the sticky tire i run..
www.canibeat.com/2010/06/blacklist-ed/
http://www.stancenation.com/2010/09/...vated-assault/
Easily swapped to my other wheels if you are into a different look though. Just will not even remotely handle as crazy as it does with the ccw's. gotta raise it up about an inch though, but heres a test fit to give you an idea.. The fronts arent pictured but i run gto spares with mh skinnies and 1 inch spacers.
http://i516.photobucket.com/albums/u...8/IMAG0285.jpg
http://i516.photobucket.com/albums/u...8/IMAG0283.jpg
http://i516.photobucket.com/albums/u...8/IMAG0286.jpg
http://i516.photobucket.com/albums/u...8/IMAG0281.jpg
The poke did not look as bad on my r888 toyos. but those tires are like 800+ a pair and last less than 5000 miles.
http://i516.photobucket.com/albums/u...r138/gto-2.jpghttp://i516.photobucket.com/albums/u...83639b2f_b.jpghttp://i516.photobucket.com/albums/u...er138/r888.jpghttp://i516.photobucket.com/albums/u...38/21br95g.jpg
most of those pictures are of it slammed on the ground at car shows. those toyos are hands down the nastiest tires ive ever ran. You get them to 150-200 degrees, and they will suck your eyeballs out of your head when you shred a turn.
seeing those old pics remind me of what my car looked like when it was slow and not a dented up pile of garbage. LOL.. :( Well not AS dented up. Pulling the fenders over 1.5 inches from stock is pretty difficult to do without skim coating the fender and repainting it in the end. The spot welds for the quarter to subframe turn into dimples after you roll over them so many times, hence the ripples in the fender lips.
Personally I'm not a huge fan of the whole narrow tire look, but I will say that car is about hella sexy. Also I love the Commodore front end.
thx! Its not for everyone, but ive got different wheels for each extreme! lol..
[QUOTE=BLACKLIST;439912]
As i was reading this, on your mods list it says you have "Pace Shitter" headers. Is that like a porta-john in the back seat? lol
lol, as in rusted out 250 dollar pace setter headers. lofl..
Im getting ready to sawzall them off instead of taking the time to remove them, lol.. And swap to 1-7/8 kooks for my blower setup.
also, That mods list is really old honestly.
Mild portmatch and polish on 243 heads
LG G6X3 camshaft
Rollmaster double roller timing chain and billet gear
SLP oil pump
Manley dual valvesprings
Manley titanium retainers
Comp magnum push rods
Fast 102
Fast 102 dbw throttle body
Duspeed OTR intake with ls7 maf
Torrid fuel rails
Weldon regulator
Weldon pre filter
Aeromotive pump filter
Aeromotive a1000
-8 return. -10 feed
Behind bars race cars custom 18 gallon sheet metal cell with sender -12 feed/-8 return/vent
47lb ev6 injectors
Pace setter ceramic 1-3/4 long tubes
catless mids
spintech 2.5 mufflers with turndowns and spintech x pipe
trick flow air intake
Katech tensioner
ASP under drive pulley(wobbley unbalanced trash, now have fluiddamper thankfully before breaking a timing chain)
A/C delete
Monster 3200 lb race pressure plate
RAM sprung full faced race disc
Fidanza flywheel
Tick performance adjustable master cylinder
Tick performance speed bleeder
Full stainless braided hose clutch hydraullics(got rid of all the snap on plastic garbage)
GMM Race shifter with lous short stick adapter and cobra bobs gasket
Harrop rear diff brace
NX large carbon solenoids
Cometic nox box 2 progressive nitrous controler
Lingenfelter lnc-002 multi step retard and rev limiter/two step controller
Meziere electric water pump
160 t stat
ngk tr5 or tr6 plugs depending on nitrous use.
Hurst line lock
SCSS semi solid trans mount
Rocksand racing solid billet engine mounts
Ron Davis aluminum radiator
Mishimoto silicone hoses
BDL Billet black anodized radiator hose clamps
Stefs Fabrication -12 catch can
Stefs Fabrication -12 breather tank
Nano 15 lb bottle
Nano large 4500psi bottle
Brand x billet bottle adjustable brackets
Taylor battery box/relocated battery
Rockford fosgate circuit breaker, distribution block (power and grounds)
Suspension Modifications: Pedders xa full adjustable coilovers. swapped to 12kg rear 8kg front eibach ERS springs
Delrin custom machined bushings throughout
Wheels/Tires Modifications:
Daily:
CCW LM-20 18x9/18x11
Falken Azenis RT 615K
Awaiting as soon as minitub per Forgeline sponsorship..
Forgeline GA3R 18x9/18x12.5
Falken Azenis RT 615K/mickey thompson et street radial
Race:
Weld RTS Black
17x4.5 gto spares/ 15x10
MH Racemaster 26x4.5x17 front runner/Mickey Thompson ET Street radial 2 275 50 15
Interior/Exterior Modifications: Interior
Recaro Pole Position leather/black alcantra seat
Willans F1 6 point harness with cam lock
Delrin c5r turned shift knob on lous short stick
Took all interior out, sanded the silver off the trim, polished the black out for full black interior conversion
HSV white faced guage faces
HSV red needles
Chris white unlocked shift light and cluster reflash with HSV startup screen
Factory shift light replaced with c4 ultra bright led from streamlite tactical flash light
Custom machined and wire edm'd steering wheel hub
Nardi Deep Corn 350mm dished steering wheel
scss triple pillar custom pod
scss dual gator dash pod
Autometer phantom 2 LED 2-1/16: Fuel pressure, Nitrous pressure, EGT, Wideband, Oil pressure gagues.
Chromolly .083 1-3/4 8 point cage
gutted rear interior
Exterior
Full oem holden conversion
Commadore vx tail lights
spoiler delete
Rear bumper cut out where insert was, rear floorboard plasma cut out and new sheetmetal flat trunk floor stamped out, sealed in, and repainted. (removed 180lbs total)
Working on functional 14 degree rake rear diffuser and sheetmetal rear wing
Front splitter with functional turnbuckles to adjust high speed downforce and stability(most of these are plastic and bolt on with screws, total cosmetic enthusiast garbage)
Pulled 2 inches over stock on front fenders, rears pulled 1-7/8
RK sport urethane side skirts
Vauxhall badges
Front grill delete (clearing some room for an oil cooler)
Removing front fog lights to build fiberglass ducts to front brake cooling vent adapters.
enough of my junk, lets see some trucks! Sorry for the multiple ot posts fellers, just didnt want to leave anyone hangin!
Man, when you start typing, it's f'n epic. You don't have much to say, huh? :lol:
play,work,daily driver it does it all
5.3 n/p tune 93
long tube
off road y
e-cut out
e-fans
hot cam
harden 7.425
vettt springs
servo
5 pinion carrier
kevlar band
Tb stall
3.73
G80
hellwig sway
eibach springs -1
eibach shocks
hd grill-cut
park wired into DRL
