i hate to disagree, but on my FLT lvl3, i blew both the input and output shafts at different times.. both times i had park, with the output shaft, i had reverse.
I checked the input shaft while the tranny was out. This morning I checked to see if it had cooler flow. I pulled the line am had good psi. So I tried to move the truck. It backed up and forward.... I put it back in reverse and had nothing. After it wouldn't move I checked the cooler line. Had no fluid. It hasn't had fluid flow or moved since. I did flush the cooler lines but not the tranny. I did clean what very little trash was in the pan and do a new filter. That's all though. Should I send the stall back to c-d to see if it did break the first time?
Sounds restricted to me. Let's see what Chris says.
Wound up being the stall.
Did it ever over heat on you at all?
No sir. Stayed 135-145.
