well I mean it looks good either way and like i said, a damn tight squeeze lol
haha thanks bro. It's not too bad of a fit, changing plugs isn't bad at all. Everything is laid out pretty well and I love the GM reliability! I've got friends with other JDM vehicles and things are always breaking while I just turn the key and go hahahah.
Honestly I have no idea. There aren't any in VT that I know of so I'd have to run against one first. But supposedly my setup will run a mid 13sec 1/4 and a stock sr20 swap can supposedly run a mid 14 at best. So I should by all means be able to take one, but on a long highway run it would probably catch back up after a while haha.
haha if I had a t56 i wouldn't have topend issues. Sadly I've got a 4l60e due to money, i picked up my 60e for $550 from a forum member, and the cheapest semi-local t56 i found was $1500. With the extra 2 gears the gear ratio's work out well, but the 4 doesn't quite cut it, plus I don't think it's going into overdrive cause the tune isn't calibrated for tire size or gear ratio.
I'm really considering doing it this winter. I don't really think much will have to change other than the tranny mount and driveshaft length. But I have no clue where the shifter lines up with the hole in the car with my engine placement you know? It would be nice to get the engine a little farther back so I can run a stock hood without a scoop but oh well.
Oh, and it is stock internals for now. I would really like to do a cam and heads, but I haven't looked into it too much yet.
Nice job.
