:LOL::stompsawayandpouts:
People thought it was 11.61 on motor because he said he got a throttle body spacer? LOL....yes, with fittings and lines. Y'all are missing out if you haven't seen the truck in person sitting on the ground or draggin' ass off the starting line. It's the only one like it.
yall are lookin at this the wrong way u need weight reduction and better aerodynamics dont need to worry about more hp just a bone stock ls3 and a vette body :lol:
thats about right AP, my truck ( ECSB ) weighed 4495 with the subs, box, and everything else in it. ran 12.16 12.28 best time, then once i took everything out it went 11.8, i say his weight is really close to being correct plus with all he's mentioned that in it!!!
Yep it was right at 4500 before the 80e swap, so I imagine its a few pounds heavier now, haven't been to a track with a scale since the swap...Ill weight her in next time I'm out...
i was on a 125, not a 150 and i wish it was a 11.5...i ran 11.65 on the 125 shot with a 60' worse than my motor times.
i have the mph for a 11.4 run if i can get it to bite the track...thats been the biggest issue.
there is a guy here that has a 6L with L92 heads and a very mild cam. first time out i believe it went 11.80's. this is n/a so yes it can be done.
damm thanks for the info
i'm shooting for 5.7L, 10.75:1CR, .581'' cam 220/222dur., 3200 stall, 4.10:1 gears, 4l60e(HD2, vette servos)
and if that doesn't get it, i have a saginaw T-10, and i'll get a zoom clutch and cal-traks with slicks
