Lol so it's not a designated name like the Bosch styles. Its just a part number.
I just put some 39lbs ford motorsports from an 2007 mustang on my truck, but I didn't cut my hardness, log in to fiveomotorsport.com they have the connectors to go from your hardness to any type injector. Its expensive but worth it. Like that u know you cant go wrong with the wiring.
i run the red top ford injectors. they work great.
you can find the part number for the new pigtails in bluecajuns thread on the ls6 intake swap on the homepage. all 8 pigtails are only about 22 dollars.
My harness is still in the build process so I was just going to check the local salvage yard and go cut some connectors off a 4.6 GT or whatever.. what if I got the 24 lb ford injectors? As mentioned earlier a 30 lb would be like a 42 under our fuel pressure? That may be too much for me. Would the 24 lb injectors net more around 36 lb at 58 psi?
no 30lb ford injectors are between 35-36lb on the lsx series fuel pressure. thats why i am going to have to upgrade my red tops for some 42lb ones for my trans am motor(408ci)
Ahhh I see. Ok that's about what I'm lookin for I guess. Around 36 lb. Sweet well that's what I'm gonna get now, some red tops. Anyone know what factory vehicles they came on??
i have a set that i no longer need. i am going to have to move up to 42lb injectors unless you want new ones. hese only have about 4000 miles on them.
isnt the spray pattern better on the smaller gm injectors than the ford inj? how bout some ls3 injectors as an option? anyone now what they are rated at?
