Wooohooo!!!, got fans coming :jump: ( paid out the ass for 'em) but got 'em comin :rock:. Now on to the thermo. What do yall think 160 or 180??? Zed
160 :)
My surrent mods are....
Replacing a blown up engine!!!!! or rebuilding one at least..
Should I get a new one, or rebuild my old one, or get a used one.....?????
choices choices
Right now, I have a 6.0L in Texas getting my TR224 cam and Comp 918 springs installed. I also purchased a set of slightly worked heads, and they just left the machine shop with a little milling. They are also receiving a valve job. BigTex is who I bought the motor from and who is getting all of my head work done for me. He also purchased me a set of thinner head gaskets to also aid in raising the compression alittle. I still have my TCI 3000 stall, transgo shift kit, and corvette servo sitting in my floor. Since I'm buying a built tranny, I am going to trade Goshawk the shift kit for his set of 3.73 gears. I'm going to order the thorley headers friday. When everything finally gets here, the last thing on my definate list will be contacting Allen to tune everything up for me. Also in the market for a new set of injectors and the underdrive pullies. Before the Thunder shootout, I will have a set of et streets and a little :nx:
I've lifted my truck .... still workin gon the tranny and tuning. :sad:
The lift kit came from Wal-mart in the jacks, jack stands, and drive on ramp section just in case anyones wondering.
Why 160? I've heard that a 180 slows the water down enough to stay in the rad to cool it down better. Just curious? :duh: ...ZedQuote:
Originally posted by 01Thunder@Jul 21 2004, 08:48 PM
160 :)
Ive noticed that with the 160* my trans temp stay down lower. and the truck runs a little cooler to.Quote:
Originally posted by storm5.3+Jul 22 2004, 07:44 PM--><div class='quotetop'>QUOTE(storm5.3 @ Jul 22 2004, 07:44 PM)</div>Quote:
<!--QuoteBegin-01Thunder
Why 160? I've heard that a 180 slows the water down enough to stay in the rad to cool it down better. Just curious? :duh: ...Zed [/b]Quote:
160 :)
as well with the bigger cam my theory is the truck will want to run a little warmer. so hence this is why I went to 160* thermo.
havnt really had any issues except for the one I spoke of on tech.
Kool, just wondering, thanx thunder...Zed
Well, money has been a bit tight for me lately. I have an ls1 cam, I got off ebay for $25, not sure when I will get that in. Right now I am just trying to get some maintenance done, changed the spark plugs, getting plug wire (any suggestions), and changed out the belts. I need to change the tranny fluid and filter, and looking into a shift kit and servo to beef it up a bit. I am also thinking about switching to amsoil 7500 oil and filter.
Randy
160 Tstat
34" Radiator
Export Y pipe
Have Allen retune my PCM - when I get it all ready to go in.
Fix my Windshield side seals - make noise with my bug shield - flap against the glass - sounds like rain - bugs the sh-t out of me.
Dennys Driveshaft - mine is steel and I feel it is causing a vibration
