Attachment 7381Attachment 7382Attachment 7383Attachment 7384
Some more pics of the fittings, and the hose. We had a string of bad luck with the 90 degree RUSSELL fittings, we bought 2 from Summit Racing and both of them leaked like crazy. I called them and told them what happened, and they said we must have gotten defective fittings so they sent us another one no charge and so far so good. I also had to buy a flaring tool to flare the lower rack and pinion lines, so that I could use the tube nuts and sleeves.
I also bought an adjustable fan controller for the transmission cooler, It's adjustable from 160-240. I have it mounted under the truck right now, I have to figure something out to put it in. $29.95 and I also wired it into a relay and fuse combination, It uses a probe inserted through the fins of the radiator to pick up the temperature.
We are still working on the transmission, no gears right now going to spend all day tomorrow going through the valve body. Until then...........
