How did you guys get the pcm to fit in the glovebox? I tried to get mine in there but it doesnt fit.
Not sure. I left my original one in under the dash and wired the new PCM under the hood. I would have had to lengthen alot of wires on the LS harness to get the PCM into the dash. Seemed easier to me to leave it under the hood since that's where it was originally.
http://i488.photobucket.com/albums/r...rsion/0171.jpg
It wont fit without major modification. I mounted mine on my passenger wheel well using the flat part from a battery tray
Mines in my glove box...was a major pain in the ass to do...
I just put it in place of the old PCM behind the glovebox. Just remove the old PCM bracket. 95-96 dash.
i just used the top of my passenger side battery tray, drilled out the 3 spots welds for the bottom bracket so its JUST the top tray. Drilled a hole in my inner fender, made a strap out of then steel and bolted it down with a 10 mm. Then I just got a drivers side battery tray and re located my battery over there since my air intake had to go where my pass side batt tray orriginally was.
