DIY oil cap breather how-to
		This is a basic how-to on making a oil cap breather, so before I begin just a word of warning
*I am not responsible for anything thing that happens to your motor as a result of building this or any injury’s acquired when building this
Now that that’s out of the way let’s begin. There are other company’s out there that make a oil cap breather but charge $40+ for them. You yes YOU can built one for sub 15$ if you have some tools at your disposal amf about 15 min of your time
Parts needed:
all parts from Summit racing
MRG-6375   	VC BREATHER GROMMET CLOSED       $2.25
SUM-G3417 	BREATHER PUSHIN COTTON/GAUZE     $10.95
Tools needed:
Drill press or drill
1” wood hole bit
Something to enlarge a plastic hole (1 ¼ drill bit would speed up making this by 10 min)
Tools is used:
http://i181.photobucket.com/albums/x...t/DSC01397.jpg
http://i181.photobucket.com/albums/x...t/DSC01398.jpg
1: take the oil cap you want to make a breather out of and using the 1 inch wood hole bit drill throw the oil cap using the inside to center the bit
http://i181.photobucket.com/albums/x...t/DSC01396.jpg
2: from the top side of the oil cap start to enlarging the hole for the grommet until it is 1 1/4 inches across (this doesn’t need to be exact but the closer the better, take your time doing this and test fit the grommet and breather periodically
http://i181.photobucket.com/albums/x...t/DSC01395.jpg
3: after you enlarge the hole in the top of the oil fill cap so you can insert the grommet and then the breather cut a hole in the bottom of the grommet.
http://i181.photobucket.com/albums/x...t/DSC01400.jpg
http://i181.photobucket.com/albums/x...t/DSC01399.jpg
4: clean the oil cap and make sure you have all the plastic shaving out of it
5: assemble and enjoy the money you just saved by putting it in your “next upgrade” fund
http://i181.photobucket.com/albums/x...t/DSC01394.jpg
