Results 1 to 10 of 23
Thread: Short stroke turbo motor
    May 2012
    Floresville
    Had anyone ever ran or heard of running
    A 4.8 crank in a 6.0 block. Does anyone know
    If the mains are the same diameter.
    I've been in turbo 1st gen small block Chevy
    Cars with short strokes and they are freakin rockets!!
    But just curious if anyone has done that with a IV gen?
    Same bearing diameters.
    Pittsburgh, PA
    Yes GM has done this already .....its called the ls327
    But 4.8 crank has same bearing diameters
    Would be a sick engine. What turbo would match up well to that?
    Sep 2011
    I've always wondered but you can't ever find much info on this subject. I think you should be the guinea pig and try it!
    99 rcsb silverado...... boosted.
    Oct 2011
    San Antonio TX
    I always thought that would neat. Ittl be different different from all the 6.0s and 408s on here.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    same concept with a 427 4.0" stroke. somewhat short stroke with big bore.
    they rev just fine!
    So theoretically all you would have to do is drop a 4.8 crank and rods into a 6.0 and it'll be just fine? Does anyone make good 4.8 rods?
    I bet a 76mm with a big turbine would be sick on that setup. And you can run L92 heads!
    Jun 2004
    george west texas
    Quote Originally Posted by o2camaross View Post
    or 2....lol
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
