Thread: 14 bolt and 4l80e swap
    found a 14 bolt in a wrecked truck at our shop so i pulled and was getting it ready to swap it in the truck. waiting on the welding shop to finish moving the perches and welding the new mounts for the 10 bolt brakes. while waiting for that lost 3rd gear in my built 4l65e so i found an 80e in the process of getting both swapped in at the same time now. when i get the crossmember back ill post it a pic so you guys can see a different way to do the 80e swap without cutting it up.
    14 bolt out an 3/4 ton light duty 4x4 so it had 6 lug axles
    getting it ready for 10 bolt disc swap
    junk open diff
    4.10s rebuild kit and detroit truetrac
    installed
    this lost 3rd gear again which led to this
    2001 4x4 4l80e with 52k on it
    yank ls1 to 4l80e ss3600 stall
    installed
    its all going in this
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
    Looks like fun!
    Looks like fun!
    gonna be calling you sometime this week gonna be getting the axle back and getting the gears setup.
    Cool deal. You'll get to check out the new addition to the worktruck.
    The gear for the awd xfer case to mate it to the 4l80e.
    My crossmember for the 80e swap
    couldn't do that on my xmember, it would be hitting on the trans pan.
