Results 1 to 10 of 35
Thread: Traction Help
    Mar 2008
    Wichita Falls, Texas
    Traction Help
    Ok..I went to the track again last night and attempted to make 2 passes...roasted the tires both times...I'm so irritated I just want to put my truck back to stock and say screw it...I have yet to get my truck to click on all cylinders at the track..it's always something working against me...I have home made traction bars and run M&H Dr's....I just can not get it to the ground...i run about 15 lbs. in the tires and i heat the crap out of them.
    I'm at a loss...do I just need to go on to real slicks? Will that make that much of a difference?
    I'm open to any ideas..Thanks in advance.
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=4251&dateline=1206558  920
    Jun 2009
    Dublin, Ga.
    real slicks! you have to grab hard with trucks to get them to start throwing weight on the rear tires.
    A lot of people (here anyways) aren't a fan of the M&H's either, may be time to go to an adjustable shock setup and get some weight off the nose and over the ass end
    Mar 2006
    Mesquite
    Yeah - try some slicks and go from there. I spun DR's too but not slicks.
    Oct 2005
    drinking your alcohol
    the hoosier 28x10.5x16 that use are good tires brad... you should try some out...
    DamnYankee: my nana failed
    Mar 2008
    Thanks guys...a true slick seems to be the suggestion of everyone..I can't seem to win for losing..lol
    Its just terrible to have too much power
    Oct 2005
    brad if youre ever down this way hit me up... i have a set you can try before you buy
    That's cute Alan.
    Tyler, TX
    i got my tires to chirp one time taking off. . . .
    www.tjc.edu
