Results 1 to 10 of 22
Thread: P1153 :(
    P1153 :(
    Anyone Know About This Code?engine Code Came Out While Cruising At 60mph.
    Something About Switches?or Switch?
    Sorry,forgot To Mention This Is On My 08'
    Birmingham, AL
    o2 sensor code, insufficient switching bank ? sensor 1. its the same problem i was having for so long!
    01 Silverado
    White Settlement, Texas
    Lol i just got that today!! twice guess its not really funny but ironic....although im sure mine is running a lot worse than yours GL
    Barks better than it bites......
    Sounds like its time for some 02 sensors to me. They run terrible when they go out. Mine was making the fuel mixture so rich on the driver side last weekend that the wideband said I had 0:1 AFR Luckily I had my HPTuners with me and locked it into open loop to drive it home with the wideband checking the fuel mixture to keep it safe.
    Birmingham, AL
    if you do decide to change out the sensors, i would suggest to just go ahead and get some corvette censors and wire them in in place of the truck sensors
    01 Silverado
    since im tuned for 93,,and i put 89 would that cause it?
    Birmingham, AL
    i doubt that would cause this problem, but it could cause others... if youre tuned for 93, use 93!!! if you wana save $3 then get a re-tune for 89
    01 Silverado
    it was all they had at the pump lol
    i already put 93 ,,ill disconnect the battery see if it goes away>
    so this is affecting performance in a way?i dont think i need 02's only have 7k on the clock
