Results 1 to 10 of 21
Thread: K&N intake problem
    Union, MO
    K&N intake problem
    I recently purchased a 77 series K&N on here. The description said 99-06, but I was looking @ it and then went to K&N website and the part numbers and design are different from 2004 and 2006. Is this going to fit or not?
    K&N shows this for my 2004 http://www.knfilters.com/search/prod...Prod=77-3021KP
    This is what I got http://www.knfilters.com/search/prod...Prod=77-3050KP
    Richardson
    It sure dosen't appear that it will.
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
    Union, MO
    I am thinking the same thing. Kinda aggravated!
    it will fit,there all the same
    Dec 2003
    Azle,TX
    im pretty sure they are all the same too
    Vortec Performance Tuned
    Fort Worth, Texas
    There are actually some small differences between an 04' and an 06'. The 04's didn't have e-fans for one and the 06's did, and the 04' trucks had 29 inch radiator and when GM went to e-fans they all got 34 inch radiators. I know this all comes into play with the K&N 57 Series FIPK (the ABS Plastic tube type) not sure on the Metal tube type. Basically I tried to use the one off a truck same year on my wifes 04's Tahoe, it would not fit. The only difference between them was the Tahoe's 34 inch radiator. Just my experience!
    Never know for sure till you try it!
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Wichita Falls, TX
    I could be wrong but I think the only difference between the 04 and the 05-06 would be that the one for 99-04 is for trucks with mechanical fans so it has a sharper, shorter curve where it hooks up to the throttle body. The one for the 05+ should have a more gradual curve where it hooks to the throttle body since there is more clearance because that bulky fan shroud is gone. Just a thought.
    Wichita Falls, TX
    looks like someone beat me with the same reply. We could work out a trade if you wanted, the only problem is mine is the plastic tube and the original owner painted it with some ugly purple mirage nonsense. or put you some e-fans on and that one should fit
    An 05-06 will fit on a 99-03 if you have efans. I have the 05-06 type on my Denali.....only because I did the same thing as you. It worked out for me 'cause all Denalis have 34" radiator and I have stock swapped efans.
    Feb 2008
    Sonoma County, CA
    I have a friend that has one on his truck that's for the 05-06 and he has a regular fan and his doesnt hit. Give it a try.
    1999 GMC Sierra SLE sc sb 4.8l 4L60E, Comp 1.75 roller rockers, graniaelli maf, garneaelli wires, Aem brute force intake, BBK 80mm tb, Nelson tune, 2/4 drop, Denali rims, custom grill, Denalli guages, Edelbrock IAS shocks, Tahoe E-fans, Nelson harness, and tune, McGaughy's 2" drop spindles, New matched coil springs, Air Lift rear lowerd air bag kit, Air Lift wireless remote
    List of things to do
    4.10 gears and a new posi, Lt headers, Cam, Heads, Intake,
