Results 1 to 10 of 44
Thread: Cam for LQ4 6.0
    Cam for LQ4 6.0
    So in a few months I would like to get a cam for my 6.0 i just put in. I must say the new power of the 6.0 is awesome, but I know I will get used to it in a few days. Plus the performance bug has hit.
    What would ya'll guys recommend?
    My truck is a 99' with a 2001 LQ4. Tuned by Dale.
    This truck is my DD, so i dont want anything over the top...whatever that is.
    I would like it to benefit throughout the whole powerand, but low and mid range would come first, since that is where i keep the tach at most. I also want to keep the stock stall since I tow my 3000 pound boat frequently...
    Would I be able to get a cam that will pull harder and keep my current fuel efficiency or increase it?
    I am not in any rush, but figured i would start looking around.
    I should probably put some money down on my trans first...different thread.
    http://i121.photobucket.com/albums/o...IMG_2118-1.jpg
    1999 Silverado 1500 Z71/5.3 to LQ4 6.0 swap/ CAI/ crappy exhaust/ tuned by COWL327
    ttt...
    Here are a few I am looking at..
    Which would ya'll recommend for my setup?
    COMP Cams® - Cam Details
    another:
    Thunder Racing Custom Camshaft
    "TR 220-112" - 220/220 .551/.551 112 LSA
    COMP Cams: XFI™ RPM, XR259HR <BR> Very Strong Torque, Good Mileage, Noticeable Increase Over Stock Cam
    Does that TR220 come in a 114? Might be better 'cause you could run it with a 2600 instead of a 3000 or so converter which would help with towing. Then again, a 224 or even a 228 on a 114 would be sweet since you have the cubes.
    Yeah the TR220 does come in a 114...Although i was hoping i could run the stock stallMaybe down the road I could switch stalls....way, way down the road.
    Dec 2003
    Azle,TX
    My first cam was a 216/220 525/535/114 it made very good power and pulled great down low.In a 6.0 it would be a good addition to the tune
    Vortec Performance Tuned
    Dec 2003
    Azle,TX
    BTW....hows it runnin?
    The truck is running great Dale. I pulled my boat for the first time today and loved it. Went up some steep hills around Jacksboro without a problem. Very happy. It is running a little rough at idle, but that is probably because I accidently put about 12 gallons of 87 in it. I need to break that habit.
    Are you able to tune the trans to where it will manualy downshift when I put it in a lower gear? This only applies for the 2-1 downshift.
    Best performance gain for the $$$ by far!
    If I can sell my ol' 5.3 I will have this cam a lot sooner. anyone want a 5.3?
    Another question. Will I need new pushrods and spring with any of the cams mentioned above?
    Feb 2009
    Roy, Utah
    Yes, you'll want to replace both.
    99 Silverado 1500 4X4- 6.0 LQ4, LPP headers
    00 Trans Am- H/C LS6 intake, 100 shot
    11.64@121 w/1.74 60' @4400' elevation
