Results 1 to 7 of 7
Thread: Front Differential Parts
    Feb 2005
    I just took off the front differential on my Escalade, due to a wining noise that it had for some time now, open it up and found both bearing broken and alot of metal shaving on the fluid? Now where can I get this parts other than the stealership? I want to get the gears as well.
    Thanks
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    Get the part numbers off the bearings and races and go to NAPA for Timken bearings. Randy's Ring and Pinion or Yukon Gear could get you replacement gears. 4wheelparts.com is always a dependable source for parts, too.
    Feb 2005
    2001 GMC Silverado
    Yeah, I believe you got it figured out there. Shipping directly to you may be cheaper than the gas to go pick them up but if you need them to rebuild the front end this weekend you may have to make a roadtrip to SA or your closest store. Be sure to call ahead and check that they have exactly what you need in stock.
    Jun 2007
    Quote Originally Posted by JJ_TURBO View Post
    Thanks
    hey jj ,thesee eskys are known for front diff issues mine was replaced 4 times before warrantee was up,we even had them put a complete diff from gm untouched by servicemen at the dealership and that went bad.so point beeing be thourough and dont skimp on any thing .not that im implying that you would .but everything possible goes bad in these front diffs.good luck.
    HotRodV6 Guest
    nationaldrivetrain.com is also a good source for quality parts and great customer service. The last two gear changes i did i went thru them and had no troubles.
    Feb 2005
    Thanks alot for the help guys, I just order the parts, gears and master kit, hopefully since this are aftermarket parts I won't have to mess with it again.
    2001 GMC Silverado
