Its been 3 years sittin.... Im from Virginia near richmond and Va beach. I built this truck in 2000 and ran for several years adding mod after mod along the way. She was the talk around here when she started running in the low 13s. At the time that was pretty quick for the new Gen trucks.. I went from the 5.3 to a 6.0 litter block when the pistons started slappin. @ the tim I had Nick augostino set up the block for me.
He was popular at that time with the LS1s.
I continued running with the Whipple Supercharger w/ 6lbs boost. No intercooler avail. at the time so we ran a .50 shot of gas just befor the thottle body. Built a Dana 60 after turning 10 bolt into Applesause on a hard Launch. Running 4.56 gears. Modified 4L60 with front Drive shaft removed .. Yes shes 4wd.. Tow hooks still stick out the bumper.... She went to rest about 3 yrs ago after breaking a few valve springs and destroying a couple rockers and got put on the back burner.. I also have a 68 prostreet Z-28...
Well I started collecting parts for the rebirth and Im back at work on her again...
New Heads 243 castings stage 3 from Pro Ports
New valve train/Comp Roller and Comp R Lifters
6.0 ltr 2002 LX intake
New stall
We gonna crank up the boost this time too
And we also hope to use EFive Alive for Tunning as well.
Her best before:
11.68 @ 121
1.49 60ft
7.19 @ 96 1/8 est
Stay tunned Illpost progress
Silverado Ext. cab 4wd Z71
6.0 ltr w/supercharger and a little gas/
A work in progress right now.
Best ET as it was 11.68 @ 121
1.49 60ft on M&H Rasemasters
Should come out this time much Quicker
