Results 1 to 7 of 7
Thread: 6.0 swap into 90 4x4
    Edmonton, Alberta, Canada
    Im having trouble finding any kind of tech pages for step by step swap of a 6.0 into a 90 silverado 2500 4x4
    what i am looking for is everything i need where specialty parts can be found and what is compatible between the 2. I have a 700r4 tranny will that work? what about all the tranny and t-case mounts and driveshaft lengths. Ay kind of help would be great or if someone could direct me to the right place.
    Oct 2006
    OKC, Oklahoma
    700R4 and 4L60E are the same bellhousing, as a matter of fact, they are damn near the same transmission. So your 700R4 will bolt up. As for the rest of it, I'm not certain.
    2004 Chevy/Regency RST, 6.0L LQ4, custom built NV MG-5 tranny by local Tranny Guru, Hurst Shifter, K&N FIPK, stock Regnecy Exhaust, 3.73 gears w/ Eaton Locker, and the Magnacharger huffer topping it off w/ stock pulley... for now
    Looking to meet people w/ LS1 trucks in the OKC area PM me
    just to let you know from what i have heard you need a 4l80e or 4l65e transmission. but maybe someone else can say if this is true or not. but i believe it is since the bell houseing is different. just a topic starter to get you some answers.
    Oct 2006
    OKC, Oklahoma
    <div class='quotetop'>QUOTE(1993chevy &#064; Dec 25 2006, 11&#58;55 PM) [snapback]77333[/snapback]</div>
    Thats a Negative, GM has used the same bellhousing pattern for nearly every tranny they every made. Even when going from small block to big block or one engine to another. The 700R4 and the 4L60E are the same transmission, but the 4L60 is electroncally controlled. The difference in the bell housing is that the 4L60 has a solid bellhousing, where as the 700 has a removable dustcover lower half. This however does not affect it&#39;s universal applications. Best of luck
    Sorry Guys, gonna butt in here. The bell housings are similar. The new Gen3 engines have a different bolt pattern. Most of the holes align except one of the RH upper holes and you can get away without that one usually. The Gen3 bell housing also bolts to the oil pan in two places. If you use an OBS transmission you will be needing a crankshaft extension and bolts so that the convertor pilot will have a place to locate. You will also have to slot the holes in the flywheel/flexplate to match the bolt holes in the convertor.
    okay, back to your regular programming.
    Alright so we&#39;ve got the tranny down now what about the rest of the swap, And will I still be able to use the original crossmembers for the tranny and t-case?
    I have not done a 4x4 swap but the 4x2 is a bolt in affair. My recommendation for bolting the engine into your truck would be to buy the steel motor mount adapters and have tabs welded to it after you drop the engine in the truck and bolt it all together to the transmission. I believe that the factory V8 cups should bolt right in the adapter plates but am not 100% sure on the 4x4s. If you do it that way you will have great success. I think one of the guys on Ebay sells an adapter plate that comes with tabs that you can weld on it to get the exact engine placement that you need.
