Results 1 to 9 of 9
Thread: which ls oil pan to use
    Feb 2012
    hey guys in trying to figure out which oil pan to buy for an ls3 in to a 2wd obs. im looking for the one that would hold the most oil and will fit properly. thanks
    Feb 2012
    any one knows if the fbody ls1 oil pan will fit and how much oil capacity it has
    go to the conversions section and you'll see it fits. Fbody and all Gen3 truck pans will work in an OBS conversion. 6 quart pans.
    Feb 2012
    do u know how much oil capacity it has
    Quote Originally Posted by chvz99 View Post
    im gonna go with 6 quarts
    Feb 2012
    thanks guys. i found some info on the ctsv it says that it takes 6 1/2 quarts , im going to do some more research and decidice on either one
    Why are you worried about that extra .5 qt? Everyone else uses the fbody and truck without issue....
    Jan 2012
    Montana
    I'd run whatever is on the motor. The only reason to change is with a custom pan and dry sump system.
    88 RCLB: LS swap in progress
    00 CCLB
    03 Yukon Denali: Wife's "soccer mom mobile"
    Feb 2012
    the motor comes without an oil pan , its an lsx376 , and I would like to put a supercharger later, so im just trying to get one that fits and holds more oil.
    i looked at the part number for the f body pan and it says it hold 5 1/2 quarts. but than people say it takes 6 1/2
