Results 1 to 10 of 13
Thread: 5.3 to 6.0 swap...now stuck on tranny decision
    Nov 2011
    NH
    so i swapped a 6.0 into my 1999 gmc 1500 that had the 5.3 . its got the 4l60e in it now but its new hp pretty much blew 2nd gear out. so would it be a better idea to buy a built 4l60e? or get a 4l80e to swap into it?? and with the 4l80e swap can i run the transfer case thats on the 4l60? or what one do i need? and will i need anything else to do the swap??? the motor im running is about 450 hp. just wondering how to fix this the cheapest way i can but still be reliable.
    id do a 4l80e bro..i broke 2 60e's and on both the 2nd gear was gone lol .not sure if u can use same transfer case
    Arizona/Utah
    Go with an 80e but swap to awd that'd be way better! Check out the stickie about swapping to awd he used an 80e. Sick setup for sure.
    Nov 2011
    Russellville, Alabama
    I'm thinking a built 4l80, my uncle has one in his 99 shortbed, and it is flawless with some tuning.
    80e all the way.
    Ponca City
    Even a stock 80
    Slowest in Oklahoma...
    Nov 2011
    NH
    yeah im going to go with a 80. does anyone know if i need a transfercase or will the one off the 4l60e work??
    Feb 2012
    clio, mi
    Quote Originally Posted by kbomhower View Post
    Im in a pretty similar swap and the flywheels on 6.0 and 5.3 are different? How did you get past this with the 4l60e? Anything helps, thanks
    Matt
    If you have a 99-2000 6L you're going to have difficulties putting a 60e behind it due to the long crank snout.
    Nov 2011
    NH
    i just got sick of trying to find custom parts and got a 4l80e. wasnt a whole lot of work and from what everyone says its well worth it in the end. im almost done with everything now and it only took a week of working on it here and there to get it done.
