Results 1 to 5 of 5
Thread: Gauge: Sending unit & Size
    On a 92 k1500 what water temp sending unit is used for the gauge? The one on the side of the block or the one next to the t-stat housing?
    If you know the size so i know what to tap that would be great too.
    Also just double checking the oil pressure sending unit from the 92 is 1/4" NPT correct?
    Bump
    Monett Mo
    use the one in the head and its 3/8 npt. And if I remeber right yes the oil one is 1/4 npt.
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
    my oil one was 1/8th NPT. It had the small OP fitting. Buy the 1/4 and if its too big you can buy a reducer.
    Thanks for the help! cant wait to finally drop this thing in
