4.8 5.7 ls1 swap questions
Im sure this has been asked before but all I could find was 4.8 to 6.0 swap threads. I found a 70k mile complete LS1 for $750 that I want to put in my truck(ecsb 4.8). If I just use the ls1 long block will I need buy any swap parts (other than a new tune)or will all of my 4.8 stuff bolt up.
I am planning on a cam(not sure witch one yet) and stall(probrbly circle D,GM 278mm HP 4L60E LS Torque Converter) while Im doing the swap also.
TIA for any input
- You may not post replies
- You may not edit your posts
