Results 1 to 10 of 22
Thread: 2001 lq4 into 2005 rcsb
    Jun 2006
    thinkin about puttin an 01 lq4 into my 05 rcsb witha 4.3... is it ok to put a 2001 enigine in the 05? kinda a noobish question i know but just wanted to make sure there wont be any compatabilty problems other than wiring harnesses... was gonna hook it up to my 05 4l60e unitil i can afford the 4l80 swap.... ohh ya and is the reluctor tooth setup the same amount?
    thanks,
    PReston
    05 Chevy Silverado. Regular cab, short bed.
    -4.3L
    - Sung Top tonneau bed cover.
    imco custom dual exhaust,
    custom air intake,
    ls1 build in progress..
    throttle is gonna be different. DBW to cable and so forth, but thats not a big issue at all
    if you go get emissions tested, that might be interesting. Usually emissions regulations require that a PCM/program for the same year or newer vehicle be installed.
    Jun 2006
    but i can sill pass right?
    -4.3L
    custom air intake,
    Mar 2006
    Phoenix, AZ
    Use the 01 longblock and reuse all your original accessories and you'll be fine. It should be a direct swap, no issues whatsoever. You'll keep your existing PCM and harness, and retune that one, so you won't have any issues with the model year in the PCM.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Jun 2006
    Quote Originally Posted by thunder550 View Post
    i can seriously keep my harness??? thats the first time ive heard that...
    -4.3L
    custom air intake,
    yeah, I don't think that V6 wiring harness is going to do you much good on a V8 GenIII engine.
    Mar 2006
    Phoenix, AZ
    Ooh ****, sorry I didn't see that you were swapping from a V6. My bad You will have to swap harnesses.
    Jun 2006
    haha yeah thats what i was thinking... so here are the only problems i think i will run into...
    swapping an older engine into a newer bodystyle truck... since there is some kind of law against this... will i be able to get around it????
    -4.3L
    custom air intake,
    DBYRD Guest
    theres no law against that to my knowledge. ull need to research ur first question there is a whole thread about the v6 to v8 swap. the throttle is the only diff i can think of everything else can be found in a post by dlh2006(derek).
