Results 1 to 10 of 17
Thread: ls1 in my 79...a few questions...
    Mar 2007
    Rockwall, TX
    i am about to be in possession of a 2000 ls1 that i am going to carb and use my th350 on for now due to lack of funds.
    what do i need to do to make my th350 work? i have heard that i may need either a different flywheel or a different converter, or possibly both.
    what modifications need to be made to the motor mounts?
    the motor has 115k miles on it. what would you recommend replacing, if anything? rod bolts, gaskets, pistons?
    and like i said, i dont have just a handful of money to throw at it, i am getting the motor for very cheap and would like to think i could put 30k more miles on it or so before having to to anything to it.
    any help is appreciated.
    thanks
    get the motor mounts on Ebay.
    The intake will require a stand-alone ignition controller, they come as a kit. you can't just throw a carb on there and have it work as far as I know.
    Mar 2007
    Rockwall, TX
    yeah, the intake and ignition is $650-700, unless i can find a used somewhere.
    i am mainly wondering about the tranny.
    Use the engine as-is unless you know there's a problem with it. I think you have to drill or slot the holes in the flexplate a little to get the holes to align. you'll need a crank extension or converter extension to mate the converter up to the LS1 crankshaft, which is shorter than the Gen1 engines.
    Mar 2007
    Rockwall, TX
    ok, thanks. maybe one day, when i have more money i can switch over the the FI....
    Use the fuel injection. It's not that much more expensive. NelsonPerformance can build you a simple 5 wire wiring harness and tune your PCM to run on basic essentials. After that all you really need is a walbro fuel pump, filter, connectors and some hose. Maybe $200 at the most in parts to do the fuel lines.
    Mar 2007
    Rockwall, TX
    but then i have to buy a tranny and converter which i figure will run about $1000. right? plus $500 for the harness, $150 for the ECM, and $200 for the fuel system..it all adds up and i am not sure if i can fork over that much in the next few months.
    how much fuel pressure does the fuel pump need to be able to support? do you have the part number for the Walbro i will need?
    and this truck will be my daily driver, only 6 miles round trip to work, after june 26th.
    Mar 2007
    Rockwall, TX
    i have heard that i can use the th350 if i have the tranny edited out and use a manual valve body...is that true?
    A manual valve body would simplify matters.
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(jshouse &#064; Apr 16 2007, 06&#58;55 PM) [snapback]90134[/snapback]</div>
    i have heard that i can use the th350 if i have the tranny edited out and use a manual valve body...is that true?[/b]
    If you stick with injection, have the PCM reprogrammed as if it had a manual trans. Not an automatic. You do not need to change out your valve body on the T-350, it can remain stock. The reason for the PCM reprogram to a manual trans is to prevent the PCM from "looking" for a trans and preventing a slew of codes from setting.
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
