Thread: BCM
    Jul 2006
    i really need the BCM to run the engine???
    You need the BCM and steering column with the correct diode'd key in it in order to run with the VATS enabled in the PCM. Otherwise get the VATS disabled and be happy.
    Jul 2006
    what can i do ..to the rest of the instalation prk lamp light radio etc ??
    i know to disable the vats a have to reprogram the pcm,, and then the pcm is free to run without the bcm and the column ....but are a lots of cables all araound?????
    i only whant the main wairing and from chile is a little dificult to go to nelsonperformance or something like that
    where can i get a wiring diagram . only of the engiene and the pcm or needed part to run the engine
    Go to www.alldatadiy.com and you can subscribe to their online vehicle information database.
