How many ground wires bolt on to the back of the head(s)? I picked up a 02 silverado body and im trying to put a motor in it and just want to make sure. Ive heard the fbodys have 3 but ive only found 2 on this truck. thx
02 Silverado
02 TrailBlazer
<div class='quotetop'>QUOTE(twobit @ Mar 16 2006, 04:48 PM) [snapback]47113[/snapback]</div>2 down into the block and 2 into the back of the block. Not into the heads.How many ground wires bolt on to the back of the head(s)? I picked up a 02 silverado body and im trying to put a motor in it and just want to make sure. Ive heard the fbodys have 3 but ive only found 2 on this truck. thx
Nice, thanks! Where did you get this illustration?
02 Silverado
02 TrailBlazer
<div class='quotetop'>QUOTE(twobit @ Mar 17 2006, 09:51 PM) [snapback]47263[/snapback]</div>My son n' law is a GM tech. Lets me borrow his login to GM's site.Nice, thanks! Where did you get this illustration?
Wow, now that's a good clear answer to the question at hand!![]()
Yea, thats awesome.
02 Silverado
02 TrailBlazer
I didn't remeber having 2 wires on the passenger side. Wire #8 is only if you have a (right hand) battery. So you probably only have 3 wires, 1,5 and 7.
(1) Ground 103 (G103)
(2) Engine Harness- H02S
(3) HO2 Sensor connector- Bank 1, Sensor 1
(4) Fuel Line Bracket
(5) Ground 104 (G104)
(6) Oil Pressure Sensor Connector
(7) Engine Ground Strap (G107)
(8) TP 1 Battery Cable (G106)
Ive only found 2 so far.
02 Silverado
02 TrailBlazer
<div class='quotetop'>QUOTE(twobit @ Mar 17 2006, 10:25 PM) [snapback]47273[/snapback]</div>Should definately have 3. 1 being the big flat cable. Other two have shrouding around them.Ive only found 2 so far.
Okay, the big flat one is the one im overlooking.
02 Silverado
02 TrailBlazer
