Using the Nelson harness, i'm still tapped into the A/C clutch compressor trigger for part of my e-fan control; soon to change i hope. Anyhow, on my '04 i recently noticed that the e-fans cycle when the mode switch is set to defrost, even w/o the A/C switch engaged. Has anyone else seen this?
And yes, I'm tapped into the right trigger wire, as the fans do work just fine when the A/C switch is engaged.
This should motivate me to test the "hot lead" on the A/C accumulator as source of a fan trigger. Having the e-fans cycling on a 10* morning while running the defroster is just![]()
