Hello again fellas,
The truck:
1994 GMC Sierra SL 4.3L v-6, auto 4x2
The problem:
Earlier tonight while walking behind my truck I noticed that I had no tail lights what so ever. I had my lights on so I checked out the rest of the lamps. All were on except the tail lamps and 3rd brake light. I paid it no mind at first and thought a bulb may have went out..but as time went by I was like why were both out.
So on the way back home I observed that my turn signals appeared to be working but were now flashing at 3 times the normal rate. I got home and parked the truck and turned the turn signals on (both right/left individually)...and as the indicator showed earlier they were actually infact flashing at 3 times the normal rate for both sides. I was like great..a turnsignal problem and no brake lights![]()
I also noticed upon further inspection that my drivers side parking lamp/turn signal lamp was filled with about 1.5" of water....how the hell did that happenanywho I pull it apart and drain the water. Still same result as far as fast turn signals.
As far as the brake lights are concerned I am completely baffled. I took the drivers side tail light assembly apart and inspected the unit..nothing out of the ordinary. everything looked good. I turned the lights on and went back to the rear of the truck...and get this..the lights were on....just barely though....i mean they were VERY dimmly lit. I swapped out some new bulbs with same result.
Does anyone have any clue where I can start trouble shooting this. I am not by no means an electrical guru....but i did check the fuses![]()
