Results 1 to 10 of 10
Thread: maf to map conversion help!!!!!!!!!!!!!!!
    Feb 2010
    washington
    I'm converting my maf to map. I know I need a 2bar map from a colbolt and a iat from diyauto tune, I don't have time to wait on shipping does anyone have a napa or gm number for a "wet" iat , I plan on using meth.
    Quote Originally Posted by ss6speed View Post
    use the grommet and iat from a 2002 or so fbody.
    i still use the old 2bar map sensor, it's PN 12569241
    It's the old square style, just run a vac hose to it and you'll have to cut and splice the factory wiring into the new wiring. also, not sure about the connector , you might want to ask for that also.
    good choice, the map tune will turn out much better!
    Feb 2010
    washington
    napa is calling the iat on a fbody a manifold air temp sensor ths the same?
    ya, that's probably it, as long as they aren't referring to the map sensor, which they probably aren't, they would use the word pressure, or ...
    Jan 2010
    Cedar Park
    Allen could you throw out a power increase going from a mail order tune to a live SD tune.. Just a guess
    Quote Originally Posted by GreenMonster View Post
    really depends on the vehicle and how much power it's currently making.
    if you check out my np site, you'll see a twin turbo gto, stock internals, mail order, then email tuned, 2bar, put down over 600hp to the wheels, so either live or email tuning can result in the same hp numbers.
    when comparing the hp increase: a live sd tune vs a mail order tune, it will be significant, because we just don't do sd mail order tunes, it's almost impossible. however, we have sent out some start up tunes for customers that were pretty damn close, but I don't recommend it.
    if you're asking about a lightly modded truck that has a mail order tune, then comes in for a live tune, the result would be more hp, not really because of the sd tune, but because we're able to get our hands on the truck and perform a good live tune with the wideband and actually see what the truck is doing and wants.
    our live tune is better than our mail order tune. depending on the mods, not by much, but there is an improvement. all this depends on the modifications also.
    Jan 2010
    Cedar Park
    Hope to be scheduling my live SD tune soon!!!!
    Feb 2010
    washington
    Crapa droped ogff my iat for a 1998 fbody and it looks like a coolant temp sensor, does any one have a part number for the one I want?
    Gm Pn 12160244 Ac-delco #213-243
    GM Grommet PN 23404388 for the airbox
    Feb 2010
    washington
    thank u!!!
