I bought a 2005 2500 HD and the instruent cluster and a/c control lights are not working. Any ideas? The radio lights work. I checked all related fuses and everything is good.
pull the radio out yet? my t/a had no dash lights but had stereo lights when i got it. when i pulled the cd player out their was a rats nest when i got it straight it had dash lights, no fun driving at night with no dash lights.
procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
and ya it will beat a hemi.
Another thing I noticed is that the radio sometimes does not shut off when I open the door. Any suggestions?
some one put a aftermarket head unit in and cut the wires and had all the wires a mess and the dimmer wire, orange i think, wasnt hooked up and nothing was right. i went to a salvage yard and cut an oem harness and some spare wire, and i got a custom kit- mount and wire harness, got the wires straight- bam, i had dash lights and all the interior electrical junk that didnt work back. if the stereo wires are straight, maby the dimmer switch?
It still has factory radio in it. The dimmer switch seems to be ok. The odometer and radio still fade with the dimmer switch.
Where can I gt the LED's from?
you might contact christian about your cluster, he just did my joe gibbs with blue led's
http://www.ls1truck.com/forums/pics-...onversion.html
MY GARAGE - http://www.ls1truck.com/forums/my-ga...ns-garage.html
2004 GMC Sierra - RCSB
