Results 1 to 5 of 5
Thread: Fuel Gauge?
    Nov 2004
    My fuel gauge go's nuts every now and then. Anyody with any advice?
    Prozac?
    Feb 2004
    Western, KY
    Yes. I've had the same problem with mine, the dealer told me that when you run the fuel pumps low on fuel that they either burn the pums out, short the sending unit out. my guess would be your sending unit is on the verge of going out.
    Correct me if im wrong but isn't the pump and sending one piece??
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
    Mar 2004
    Springfield
    I wouldn't worry to much about it, mine lies to me at times as well. Now if it tells you the tank is empty and you just filled it up, then I would be worried. Means you got something wrong with the fuel sending unit, or the cluster itself may have to be replaced.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Check that the ground wire at the tank isn't broken. Also follow the wire from the tank to the front of the truck and check for chaffing. Fuel pump/gauge sending unit is about $400 new so I would exhaust all options before replacing it with a new one.
