For my first post here I need some help with something. My wife's truck is a '96 Silverado and the headlights just aren't bright enough to suit her. I'm intending to add a system like the Painless relay advertised and sold by Summit,,, But before i do I figured I'd ask if there's another way to achieve this without buying a premade harness. Anyone have a link or suggestions??
From the Summit catalog:
"When you switch on the high beams on your Chevy or GMC truck, the low beams go off. With this Painless Wiring relay, you can have all four lights on at once. This increases the intensity and improves the spread pattern of your lights. Easy 10 minute installation. A 30 amp relay, color coded wiring, 30 amp circuit breaker, and instructions are included. Works for any 4 headlight system."
