im looking for the ecm pin lay out for my 93 tbi, can anyone hook me up?
new project
37 m-series 3/4 ton chevy truck,
plans: 5.3/4l80e, cut down ford 9 inch, 6piston brakes
V6 or V8? TBI or Vortec?
v6 tbi vin z
new project
i found the pin lay out but its for a
94 350 tbi
i think it will be good enuff for wut im trying to do tho
i have no 1st gear, manually down shiftin it or just putting it
in drive
so i think its a wiring problem, so im gonna check over everything to
make sure its not my tranny itself
because the tranny was rebuilt, not saying its not a problem within the tranny
but im just trying to make sure
new project
As far as I can tell, the 93 4.3L engine only used wiring for the torque converter lock up control. The kick down is controlled via a cable from the throttle body down to the valve body. The shift would be controlled by a set of governor weights that swing out with speed to signal the shift. I don't believe they put the electronic shift transmission until at least 94. I could be wrong, but my manuals don't show a 4L60E in 93.
i got 4l60e in the truck
new project
