Results 1 to 10 of 10
Thread: How much paint?
    May 2010
    How much paint?
    I want to paint my 90' single cab step side. The top I want to be black where the body line is and the bottom kandy green. Can anyone verify how much paint is needed, what site you recommend to order the paint, and all the stuff I need, like primer, reducer, stuff like that.
    Right on fam.
    prolly about a half gallon of each color, primer, reducer, hardener, and clear. Ive usually just searched online my hot rod black is usually over a 100 bucks a quart and i found it on amazon for 55 bucks.
    Did you know Harley paint is around $600 a qt? That's nuckin futs.
    D-bags pretty much right on, only I'd get a couple gallons of primer just so you have room for block sanding, since your painting it black you'll want to block it out a couple times, at least. Get ya some guide coat too.
    Dec 2008
    san antonio TX
    i bought 1 gallon of paint, and once i mixed it 1:1 i had 2 gallons more than enough, i painted my truck 1 color though.also bought 1 gallon of clear.
    Took 1.5 gallons of color on my 92 ECSB due to the victory red color being translucent.
    Feb 2009
    tcpglobal.com is there i buy mine
    02 5.3 sierra rcsb,its stock i swear ....
    Quote Originally Posted by sleeper1500 View Post
    im d-bag
    May 2006
    Waco TX
    Are you doing a base clear? Or single stage? Gallons are way too much. You tint your sealer to the right tint and any color should cover in 2-3 coats of base. Let me know more specifics. I can also mix it up at cost here at the shop using high quality PPG products
    May 2006
    Waco TX
    Where are you located?
